Smog pump kit, do I need it?
6 replies to this topic
  • EX_CR500_Rider
Posted May 02, 2001 - 06:31 PM
I saw a picture of the smog pump removal kit. It looks like some pretty simple parts. I think I can do this without the kit by blocking off the ports myself. Is there any adjustments that need to be done once the ends are all blocked off? Any suggestions? Thanks
[This message has been edited by EX CR500 Rider (edited 05-03-2001).]
  • Guest_Guest_*
Posted May 03, 2001 - 08:44 AM
If you are considering a big gas tank you will have to remove the emissions device to get the tank on. You don't have to make any changes or adjustments if you install the block off kit. The kit has everything you need.
Good luck
Kevin
[This message has been edited by KBeach (edited 05-03-2001).]
  • ToddW
Posted May 04, 2001 - 02:53 AM
Spend the 20 bucks and get the kit from XR's Only or Applied. Both of them are machined from AL. billet (high quality). I have CNC I can use and wouldn't waste my time for a $20 part.
  • EX_CR500_Rider
Posted May 04, 2001 - 07:30 PM
Yes, I broke down and baught the kit. But, I was right it would have been a piece of cake to make a flange and locate two 1 cent rubber caps. My question is, where do the crank case gasses vent now?
  • Guest_Guest_*
Posted May 08, 2001 - 10:29 AM
Oops
[This message has been edited by KBeach (edited 05-08-2001).]
  • Guest_Guest_*
Posted May 08, 2001 - 10:36 AM
The crankcase vents to atmosphere now. I used the smog hoses to make up a connection from the crankcase to the air box. Now, under high loads, I have vacuum assist for crankcase ventilation.
  • ToddW
Posted May 08, 2001 - 10:41 AM
Are you talking about a smog block-off kit for the XR650R or XR650L? We all have XR650R's and that block-off kit is a billet aluminum plate that uses o-rings to seal two ports in the head, where the smog pump went. The crank case gases vent from the case under the carb to the air box (you can run a K&N breather instead). Hope that helps. If you have a XR650L check out this link for more info! http://groups.yahoo.com/group/xrlug
Todd
  • 3 replies
  • 22 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
