white bros e series?
8 replies to this topic
  • jjk
Posted August 31, 2004 - 06:04 PM
I took my discs off to inspect my exhaust.. At the end of the discs, closest to the back there is a flat disc.. Is this the spark arrestor? If i remove it will it free up more power? Also I am running 6 dics, what does adding more or putting less on do for the power?
  • TallJohn
Posted August 31, 2004 - 11:32 PM
The flat disk is the spark arrestor. More disks = more power = more Db. I think 6 is about the minimum you should have so depending on how loud you are prepared to go, try taking some out.
  • jjk
Posted September 02, 2004 - 06:55 PM
I romoved my spark arrestor today to test it out. It reved faster and had less power. I was still curious if anyone knows what adding discs does for the power? More discs more bottom, or less bottom? less discs more top?? :thumbsup:
  • Nate_R
Posted September 02, 2004 - 08:08 PM
You should try a coke can it will give you more power than what you got, Bubba. :devil:
___________________________________________________________________ :thumbsup:
  • jjk
Posted September 03, 2004 - 08:09 AM
You should try a coke can it will give you more power than what you got, Bubba. :awww:
Well then it would be too heavy, and if it was too heavy i would lose sleep and not be able to function. and if i couldnt function then i wouldnt be able to interact with all of my nerd friends on an intellectual level...... :devil:
  • yamaharichey
Posted September 03, 2004 - 01:55 PM
The more discs more power in the higher revs, the less discs more power in the bottom end. try 8 discs that semms the best for sound and power.
  • Nate_R
Posted September 04, 2004 - 01:52 PM
I made a mistake you should not use a coke can. Use a mountain dew can you nerd.
  • luke_n
Posted September 06, 2004 - 04:33 AM
I got 12 so i put em all in, sounds alright to me.
  • redrocket190
Posted September 07, 2004 - 11:36 AM
The documentation that comes with the pipe suggests that 12 discs will get you the best powerband for a WR400F. Using less discs makes the bike quieter, with less top-end power.
