copper shavings in oil ?
7 replies to this topic
  • steashy27
Posted August 31, 2004 - 12:57 PM
Hi all ,
have bought 00' 426. The last 3 oil changes have
found copper coloured shavings along with the usual metal shavings as per previous postings .Has any one got any ideas .
Have taken off head and cylinder to check crank .NO PLAY and within tolerances .
cheers Steashy27
  • DrThumper
Posted August 31, 2004 - 01:24 PM
Oil drain bolt washer may be made of copper (or brass), as well as the frame tank drain bolt washer....other than that I can't think of anything else made of copper/brass? Valve guide/seals? :devil:
Thats a good one....? :thumbsup:
  • yzf450jack
Posted August 31, 2004 - 03:31 PM
The only thing that I can think of in the motor is the brass bushing in the clutch basket I would look in the clutch Most stuff you find in your oil is from the clutch
  • sirthumpalot
Posted August 31, 2004 - 06:37 PM
The clutch would be my first guess too. There is usually a brass bushing attached to the basket. Take it apart and check before something lets go.
  • RoosterJ
Posted August 31, 2004 - 06:43 PM
Stators have alot of copper in them, it might be a good idea to pull the left cover and take a peek.
  • Davidyz450
Posted September 01, 2004 - 06:55 AM
I'm not sure about yamaha engines, but in car engines when the crank or rod bearings start to go out, there can be copper looking shavings in the oil!
  • stainlessTT
Posted September 01, 2004 - 04:42 PM
Thats what I was going to say also. I recently bought a remaned 5.0 V8 from S&S Engine. About 2 week after driving it the motor started knocking like crazy at higher rpms. when I took it out of my jeep to send it back there was gold glitter like shaving every where.
As far as dirt bike motors go :thumbsup:
let us know if you find the problem :devil:
  • MXof21
Posted September 02, 2004 - 03:21 AM
I have heard that some bearings are plated brass, when the plating wears down you will start seeing brass in your oil filter.
  • 0 replies
  • On January 15, 2017
  • Hot  30 replies
  • Hot  28 replies
