helmet cam problem (short vid).
Posted 30 August 2004 - 03:58 PM
are the helmet cam batts dieing? or is that the wire pulling out of the cam? any ideas?
thx
Click here for a sample of the messed footage
Posted 30 August 2004 - 04:42 PM
I had a similar problem taping a friends wedding, turned out to be a bad tape. Nothing could be done unfortunatly.
Posted 30 August 2004 - 05:30 PM
Posted 30 August 2004 - 07:00 PM
it was doing ti before the branch and went down hill form there.
2-
ok thx, thought it might be the batts.
vid coming soon. frame editing done. now just the sound.
Posted 30 August 2004 - 08:44 PM
What format is it?
Greg
Posted 30 August 2004 - 10:44 PM
Quote
What format is it?
Greg
It's a DivX avi, shouldn't have anything to do with your quicktime software.
As for the lines, it's the batteries.
Walmart should have some nice rechargeables for relatively low price, I think they're around 2800mAH.
Posted 31 August 2004 - 05:27 AM
Posted 31 August 2004 - 07:15 AM
Try backing the outler lense cover off a bit so it's not sealed with the o-ring, maybe that could give it some airflow. (probably not)
That's about all I can think of.
In conclusion... I have no idea how to solve it if it's doing it constantly..
Be the guinea pig, goto your local computer store and ask for some Artic Silver (or some generic paste, they'll give it to you for free) thermal paste (used for cpu->heatsink heat transfer) and rub it on the splines of the outer lense like you would locktite, but in gracious amounts... See if that helps... seriously.
ps - If you've not caught on... I'm talking out of my bum.
Posted 31 August 2004 - 08:04 AM
Quote
no sh-t sherlock
Posted 31 August 2004 - 08:11 AM
Quote
Quote
no sh-t sherlock
The point is, Simon, that simply disconnecting the power for a few minutes and letting the batteries recover vs letting it discharge at a constant rate lets the battery refresh itself and thus you get MORE power to work with, not just equal to the few minutes you had it disconnected..
There's these things called electrolytes that are drawn from the plates in the battery, if you suck it all down at once vs letting it recover you get less overall battery life.
Look at it this way, you take one drop of ink into 1 gallon of water. You IMMEDIATELY suck that ink up through a straw... .. It's all gone.. poof. just like that. Then you take a drop and let it sit in that gallon for a while and let it diffuse, suck a bit of it up at a time intermittently.. After hours of sucking you'll still have ink in the water.
That's the point I was making.
Posted 31 August 2004 - 08:23 AM
and turn on your msn for a min.
Most people wouldn't deduce the above reasoning like you and I ('cause we're super duper smart
Posted 31 August 2004 - 09:29 AM
Posted 31 August 2004 - 11:43 AM
Quote
Now that's funny!
Posted 31 August 2004 - 11:58 AM
Quote
I'm here... Get on msn you goof, or upload it to the server.
Posted 31 August 2004 - 11:59 AM
Quote
Quote
Now that's funny!
Oh that's nothing.. Just wait till I get it published in the National Enquirer, or at the least some spook website places.
Posted 31 August 2004 - 01:00 PM
any one know how i can import or export .wmv with premier 6? right now I'm exporting then converting.
