Anyone using oil filters besides Yamaha OE for $12?
17 replies to this topic
  • djv5
Posted August 30, 2004 - 08:20 AM
Can anyone recommend an oil filter for my 2003 WR450f besides the $12.00 OE Yamaha ones. I am already aware of the stainless steel ones for $70.00 and am not interested in those right now. I have heard of people using Fram Oil filters that you can buy at Walmart. If you use other brands of oil filters, such as Fram, do you remember the part #?
Thanks for any help you have to offer.
  • noslo98
Posted August 30, 2004 - 09:06 AM
I use the k&n one i pay 8.00 for it.
  • ddialogue
Posted August 30, 2004 - 10:39 AM
My stainless filter has already paid for itself FOUR times! :thumbsup:
  • SXP
Posted August 30, 2004 - 10:54 AM
http://www.cyclegear...pt.cfm?tier2=56
$3.99 for the HF-141 (03-04) filters. I understand these are the same as the K&N filters (made by the same company).
I bought 10 of them and use them in my 99 WR400 instead of the more expensive mesh screen filters. Fits perfectly and I've had no problems with them.
  • mtrablue
Posted August 30, 2004 - 07:43 PM
K&N
  • JVP
Posted August 30, 2004 - 09:27 PM
These bikes need their oil change as often as I do! :devil: I suggest using the Scotts Oil Filter. After about 4 changes it pays for itself. :thumbsup:
  • JerseyDirt
Posted August 31, 2004 - 06:04 AM
I've also been using these for the past year and am vey happy with them. Perfect fit and good quality.
  • YamahaSteve
Posted August 31, 2004 - 07:06 AM
I just bought the scotts oil filter becasue I change my oil ever few rides and those OEM filters are way too pricey... anyway, 70 bucks for the scotts is only like 6 changes with the OEM. For me that is about 3 months or so. If you ride alot, you should reconsider the reusauble filter.
  • simch
Posted August 31, 2004 - 08:45 AM
Do you guys change the filter every oil change?? I have done up to now, but its only every 200 miles or so and seemed sensible on a enw bike that was being broken in. It was my intention to change evry other oil change from now on.
(PS I use the hi flow brand too, suplied through my local Yamaha dealer!! They use them on their supermoto bikes).
  • YamahaSteve
Posted August 31, 2004 - 03:42 PM
I used to skip the filter every other oil change (my oil changes are every 100-200 miles), but now with the reusable I clean it out every time.
  • Jethrro
Posted August 31, 2004 - 05:48 PM
K:n makes a Stainless steel one that's reuseable. There are a few different ones that they make paper and steel. I've been running the latter and love it. And I don't have to buy the overpriced yamaha stuff.
  • yasotay1
Posted August 31, 2004 - 07:22 PM
Most of the guys I ride with ride WR's and won't use a steel filter. Two reasons really. First they don't filter as well as the paper filter. Second, when cleaning the filter there is always a small chance that you may inadvertantly wash particles into the filter instead of out. Of course there are many schools of thought in this area and I've run stainless filters in a CCM I have and never had a problem. I love my 426 and I'm not taking any chances.
  • YamahaSteve
Posted August 31, 2004 - 09:27 PM
I am not a filter expert, but the Scott reusable filter suggests on the package that it filters better than a paper filter. Dunno, maybe they lie. They use 35 micron stainless mesh. Supposedly paper can get down to 10 microns, but paper does not have the "holes" in it controlled like a woven mesh and can pssibly have much bigger holes in it across it's surface. That was how it was explained to me. Food for thought.
  • ncmountainman
Posted September 02, 2004 - 10:03 AM
i've been using the 02 426 filter and cleaning it every 3rd change,and after 3 cleanings buying a new one, now it probly doesn't filter as well as paper but you get a higher flow rate and if you change oil after every ride(its only a little more than a qt.)its not a problem. now there are some people who say that the 426 filter is a different size and won't work,they are wrong! the crap stuck to filter is evidence enough for me that it works. and it does'nt get sqaushed either as some people have stated,the only reason i change it after 3 cleanings is to make sure the rubber does'nt get damaged. you probly could use it many more than 3 times. :thumbsup:
  • beezer
Posted September 02, 2004 - 10:23 AM
Its difficult to clean an oil filter completely.
Thats why I don't use them.
But people do and get good results with them. Its more important to change your oil often.
I figure I have 6,000 invested in my bike, oil filters are not where I want to take chances.
Yamaha parts prices are HIGH.
  • ncmountainman
Posted September 02, 2004 - 10:49 AM
the 02 426 filter is wire mesh and you can see clear through it, as far as cleaning its quite simple. put it a can of gas shake it around look it over and put it back. :thumbsup:
  • SXP
Posted September 02, 2004 - 11:43 AM
Quote "the 02 426 filter is wire mesh and you can see clear through it" unquote, which is exactly why I'm doing the opposite of you - using the paper instead of the screen type for reasons (correct or incorrect) stated in a couple of posts above.
And you are right, the filters are interchangeable as I'm using the 450 paper filter in my 400 and it fits just fine without any distortion.
  • ncmountainman
Posted September 02, 2004 - 04:30 PM
well they still sell it as replacement on the 426 and they seem to be holding up! and i change my oil every ride anyhow so i'd rather have the increased flow. i also run a magnetic plug which helps with the minute particles. {"to each his own") :thumbsup: but my way is cheaper!
