replace the basket?
2 replies to this topic
  • yzquadracer
Posted August 30, 2004 - 06:45 AM
i have an 03 450 and i just got a hinson inner hub. i already know im going to put new stock plates back in with it, is it worth gettin a hinson basket right away as well to compliment it, or will my new inner hub do just fine? thanks
  • yzquadracer
Posted August 30, 2004 - 03:14 PM
  • TimFurryBalls
Posted August 30, 2004 - 03:38 PM
Get the basket. You mind as well. It will definitely flow way more oil than stock. Once you compare the two, you'll see. A Hinson pressure plate also gives you more consistent clutch actuation and oil flow as well.
  • Hot  131 replies
  • Hot  33 replies
  • 9 replies
  • 0 replies
Need help by Goforaride
  • Hot  68 replies
