Tensioner release Q
3 replies to this topic
  • directconnection
Posted August 28, 2004 - 06:19 PM
Checked cam timing and found it was allready at YZ timing. Not sure the exact procedure on the tensioner. Do you let it un-wind and snap itself into position, or do you manually go past this point and ADD tension? I am guessing let it find it's own spot by unwinding itself on it's own, but the chain felt a tad looser than when i removed the valve cover for the 1st time. Probably me just being paranoid :thumbsup:
Steve
  • endurodog
Posted August 28, 2004 - 08:01 PM
Yes just let the tension off, don't add tension to it once it's released.
  • Hamish
Posted August 28, 2004 - 10:30 PM
what eurodog said.
After it's all back together rotate the engine a few times in the running direction by hand and it should settle in.
  • directconnection
Posted August 29, 2004 - 07:29 AM
Thanx guys!
