new to the crew
5 replies to this topic
  • YZ250F_Rider
Posted August 28, 2004 - 12:14 PM
So I plucked the deposit down today for an 05 450f.
I am putting a 756 on the rear and a 773 on the front. But I'm wondering if you guys get bigger rear sprockets for them like most everyone does for the 250's.
I may need to renick to Bipolar_Rider or something. :thumbsup:
  • Satch0922
Posted August 28, 2004 - 01:36 PM
you need to save your pennies for a different chain....I can't tell you how many have learned the hard way
  • YZ250F_Rider
Posted August 28, 2004 - 01:42 PM
Sure I can believe that. The 250f would stretch it's chain in short order. I'm just wondering if anyone goes for a higher tooth sprocket or not.
  • MxHuggy
Posted August 28, 2004 - 02:27 PM
I went up to a 50 tooth. I wanted to be more in the powerband in 2nd on the track that we ride. It if pretty tight and I was rarely seeing the high end of 2nd and never 3rd. It did the job, however a year later I find myself going faster and pulling 3rd all of the time on the same track.
My suggestion is to ride it stock for a while and then see where you want to be gearing wise then.
Enjoy the new ride! :thumbsup:
Posted August 28, 2004 - 09:40 PM
As Huggy points out, it will depend on where you ride it. In his case, gearing it down made it match up with his favorite track better. On mine, I went 2 teeth smaller in the rear, making it higher geared. It has the effect of making the spread between gears a little wider, and makes low gear a bit more useful. A lot of YZ450 riders around here raise rather than lower the gearing on the big bike.
  • YZ250F_Rider
Posted August 29, 2004 - 04:37 AM
Thanks guys. Based on my 250F I figure I have about a week on the stock chain with the 450 before I have to do something. So I should be able to see how it does in that amount of time.
74 Triumph Trident
Now thats a bike! :thumbsup:
  • 9 replies
  • Hot  47 replies
  • Hot  36 replies
  • Hot  33 replies
