High altitude jetting for 99 WR400
2 replies to this topic
  • Rocky
Posted August 27, 2004 - 08:58 AM
I searched the site and did not see anything specific for this altitude.
My 400 was re-jetted for sea level couple of years ago (don’t remember what the specs were).
I moved the bike to my summer home (altitude is around 7000ft). It back fires on deceleration, also there is a little bit gurgling from ¾ to full throttle.
I dropped the main jet from 175 to 165 – no change. Also dropped the needle clip to the 2nd groove from the top.
PS: I have the stock can with the Baja insert, air box lid removed, and uni filter, gray wire is cut.
What are your recommendations?
Thanks
  • Oasis_Flame
Posted August 27, 2004 - 09:50 AM
3800ft. to 8000ft. I found that a 162 main jet and stock needle on #4 clip all else is stock. At 8000ft. the bike is a little rich but still very rideable, you may want to use a 160 main then tweek the needle for your own liking. :thumbsup:
  • Gee
Posted August 27, 2004 - 06:11 PM
You might want to try a smaller pilot jet as well, I'm running a 165 MJ, 42PJ, clip in 2nd postion from the top on the needle.
