99 YZ400 float height
1 reply to this topic
  • Dafan
Posted August 25, 2004 - 07:23 PM
Hi can anyone tell me what the stock float height is for a 99 YZ 400? It has the round floats instead of the square 426 floats. Thanks
  • Big_D
Posted August 25, 2004 - 10:56 PM
The Stock float height is 9mm.
Here is the Clymer procedure (which actually makes sense):
>Remove Carb
>Remove Float Bowl
>Lightly touch the float to ensure the float valve is seated
>Hold the carb so the float valve remains seated, but the spring loaded pin in the valve is not being compressed by the tab on the float.
>Measure the distance from the float bowl gasket to the highest point on the float. (9mm)
>If the float height is incorrect, bend the float tab in the appropriate direction and recheck.
>Reinstall float bowl.
>Reinstall carb.
The actual procedure says to remove the float to bend the tab but if you use a tiny screwdriver or pick to adjust the tab carefully there is no need.
Just had to redo mine yesterday. :thumbsup:
  • 10 replies
  • Hot  30 replies
  • Hot  36 replies
