Forks on 04 WR 450, what did you do?
9 replies to this topic
  • MathProf
Posted August 25, 2004 - 04:35 AM
I think that my forks could work better.
Has anyone made changes to their forks that made the action better?
I have a stock spring, 5.5 inches oil level, 5 wt oil.
I was considering 2.5 wt to soften the action in the trees, but would it be better to buy new springs before I change the weight of the oil.
I don't want to waste my time, so some help would be appreciated.
I have looked at peoples signatures to see what people have done, but most people seem to change things for more power. There are few suspension mods done.
  • ncmountainman
Posted August 25, 2004 - 06:08 AM
i went to honda 5w fork oil and it does provide easier action,don't worry about it being red my bike hasn't spit it out yet! come out a little on your compression dampening,i run 16 out on comp and 8 out on rebound i've put .48 springs in though. this allows me to use the entire stroke without bottoming(unless i screw up!) :thumbsup:
  • Beta_Man
Posted August 25, 2004 - 06:27 AM
I removed the mid-valve from the forks, and that really helped. Now it has a nice stroke all the way through the forks, with no hit in the middle.
  • MathProf
Posted August 25, 2004 - 07:40 AM
This is the first time I have heard about the mid-value.
Mid stroke seems to be the big problem. I bottom too often, but if I increase the compression the action becomes harsh.
I'm currently at the softest compression setting.
Can you tell me where and how to handle the mid-value.
I'm wondering if a softer spring would make the mid stroke better or if the stock spring will work once the mid-valve is removed.
Is this where people talk about changing the stack to get more compression at certain places in the stroke??
  • jerryls
Posted August 25, 2004 - 08:40 AM
If you're bottoming too often, you need to add more fork oil.
All I did with my forks was change the oil (5 wt) and they perform nicely. The oil in the forks for the factory was like black sludge.
The forks do seem a bit stiff when riding slowly, but when I'm smacking off the top of whoops in 4th gear, they work just fine.
  • ncmountainman
Posted August 25, 2004 - 09:10 AM
how much do you weigh? if your over 180 then the thing is undersprung for sure. going to a softer spring will make you bottom worse! yam makes spring spacers you can use up to 2 in each fork they go under your spring and increase preload without changing the spring rate therefore you use more of the available resistance throughout the fork travel. :thumbsup:
  • MathProf
Posted August 25, 2004 - 09:52 AM
The forks work OK at speed, a little harsh at times, but OK.
The problem is I tend to race hares scrambles which is mostly technical tight trails but the occasional MX track section causes some bottoming if a over-jump a table, for example.
I have changed the oil a couple times (5 wt) already, and the action is still not what I think it should be.
I'm exactly 180. There is always some compromise when your terrain and course vary the way a hare scrambles course varies. I could increase compression to find a happy medium, but now the bike is only happy at MX speed.
I appreciate your responses and I'm thinking about all of them.
  • ncmountainman
Posted August 25, 2004 - 10:07 AM
try the washers they are cheap and slide right in after removing the spring,and are you using the honda fork oil? it really did help. :thumbsup:
  • Beta_Man
Posted August 25, 2004 - 10:24 AM
I tried diffrent levels and weights of oil but never got the results I wanted. I had to have the compression all the way out to get the smoothness I wanted, but then it would bottom out too easy. With the mid-valve removed I could make the compression alittle stiff yet still have a smooth fork. It's not that hard to remove the stack of shims that are for the mid-valve (didnt take any longer than changing seals). But unless you know what you are doing and what to remove it can be quite complicated.
  • MathProf
Posted August 25, 2004 - 12:31 PM
The front fork is too stiff already I don't think I want to shim it, right?
I felt like something was wrong with the fork and you described it perfectly. I do all my own maintainence, so I'll look at the exploded view and see what it takes.
Thanks for the reply.
