Sagging Suspension
2 replies to this topic
  • Eric_F
Posted August 23, 2004 - 12:24 AM
On my 2002 WR426, I usually keep it on a jackstand when not in use. I noticed that when I take it off the jack and lower it down, the front shocks will sag ~1 to 1.5 inches under the weight of the bike itself. For some reason today was the only day I really looked for something of that nature and this concerned me. I was just wondering if this was normal, and what to watch out for as signs of suspension wear.
Thanks!
  • Indy_WR450
Posted August 23, 2004 - 04:17 AM
That seems like normal sag to me. But it may be time for new front fork springs! All springs eventually fatigue and weaken.
  • ncmountainman
Posted August 23, 2004 - 05:56 AM
yam makes adjustment washers that prelaod the spring p# 4SS-23364-LO i had the same prob put two of these in(two is the most)and problem solved quite cheaply. sounds like you need two also. :thumbsup: btw that p# is for the 04 with 46mm forks ,i don't know about the 426.
