Heavy Breathing?
12 replies to this topic
  • XR6
Posted August 22, 2004 - 03:02 PM
Hi Folks,
First I'd like to say hello as a newbie to both the XR, enduro bikes and this site.
I just bought a 1994 XR600R today - my first big single bike and overall I'm pretty pleased with myself :thumbsup:
I'm concerned that the crankcase breather seems to be breathing a little heavily: when the bike is idling there is quite a strong pulse of air coming from the crank breather pipe. I'd really like to know if this is normal or if it shows signs of bore wear (compression leaking past the rings?).
Thanks for all and any advice you can offer,
  • AzMtnThumper
Posted August 22, 2004 - 10:56 PM
Mine blows out a bit too. Don't really know if it's normal or not. :devil: Mine starts right up if I follow the drill, has plenty of power and doesn't use any oil. Welcome to the site. :thumbsup:
  • frankstr
Posted August 23, 2004 - 04:26 AM
Can't answer the breathing ? :devil:
But welcome aboard TT :thumbsup:
  • XR6
Posted August 23, 2004 - 02:02 PM
Thanks for the welcomes. I guess I'll just ride it and see how far I get. I'm sooo looking forward to next weekend....
Cheers & beers,
  • roosterk0031
Posted August 24, 2004 - 07:54 AM
I would think it's pretty normal, when that piston moves up and down every stroke it displaces 598cc of air so that much air has to go in and out of the crank case every stoke. Although I've never noticed on my 87 xr600. David
  • flyinW
Posted August 24, 2004 - 01:53 PM
Ya... the huffing thing is normal... the OE factory manual discusses ways to be sure that the hoses are routed properly to ensure that the outdoors don't enter into the crankcase.
L8R :thumbsup:
  • XR6
Posted August 24, 2004 - 02:40 PM
Thanks for putting my mind at rest on that one - can't wait for the weekend to come around.
  • Rockjockey
Posted August 24, 2004 - 02:52 PM
Check out the K&N crankcase filter it works great and looks sano. :thumbsup:
  • Old_Man_Time
Posted August 24, 2004 - 03:18 PM
You do know that heavy breathing draws masquitos? Might be a good idea to keep a safe distance from you if riding with you. :thumbsup: :devil:
  • XR6
Posted August 24, 2004 - 03:46 PM
The wobbly way I ride, another country could be considered the safest distance :thumbsup:
  • smashinz2002
Posted August 24, 2004 - 08:03 PM
Hey there from UK, That huffing thing is normal dude. When the piston goes down on it's stroke, it's pressurizing the crankcase and it is expelled through the breather. A friend of mine has an '87 XR600 and it does that same thing, not a problem. Just make sure that hose never gets pinched.
And have fun riding your newly aquired XR600R!!!!!
'00 XR650R
'04 KX500
  • roosterk0031
Posted August 26, 2004 - 05:44 AM
The hose the comes out of the crank case should hit a "t" with one hose going down, and the other going up, I believe the hose on the bottom is kind of crimped to prevent water from going up it and let oil out, I think the up branch goes to the air box to suck fairly clean air in. Where are you seeing the puffing? I've never noticed it on mine. David
  • XR6
Posted August 29, 2004 - 04:06 PM
Now I've thought more about it the original question was probably a dumb one - I've only had multi cylinder machines before where the down strokes of one cylinder would be offset by the up strokes of another, thereby equalising crankcase pressure.
On a single cylinder there is always going to be crankcase pressure.
roosterk0031: I never saw any puffing - just felt the pressure coming from the crankcase breather on my hand as I was checking the bike out. I now know that it's nothing I should have been concerned about.
Thanks to everyone for the sensible and accurate replies.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  141 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
  • 3 replies
