Weird problem... engine dies when you turn the handle bars to the Rt??
6 replies to this topic
  • Hopper
Posted August 21, 2004 - 07:34 PM
Has anyone seen this problem before? The engine will die just before the forks reach full turn, (about 1/2 inch before full turn is met). I've looked around the forks and there are no wires exposed or being pinched... just don't get it... Please help is ya can. Tks.
  • tdd6405
Posted August 21, 2004 - 07:53 PM
try to pull your throttle cable out a little bit so it doesnt get pulled tight when u turn the wheel
  • cowboyona426
Posted August 21, 2004 - 08:28 PM
I would double check the kill switch wires (especially if you run tall bars) and the decompression lever cable (if you haven't done the 450 cam mod).
  • Hamish
Posted August 22, 2004 - 12:53 AM
I wouldn't mind betting your decomp cable doesnt have enough freeplay and it pulling your ex valve open when you turn your bars
  • Satch0922
Posted August 22, 2004 - 03:17 AM
He's back!! (and he is correct.....)
  • John_Lorenz
Posted August 22, 2004 - 07:07 AM
The decomp is engaging
check the route of the decomp cable.
  • Jeffro426
Posted August 22, 2004 - 07:47 AM
Yup, probably the decompression cable...when i tore my bike apart last year i had this coiled spring left over and couldnt for the life of me remember where it went. After my first ride every time i would turn the bars right, it would make this nasty sounding knocking noise and would die 9 out of 10 times....turns out that spring was what kept enough tension on the decompression lever at the head to keep it from engaging! :thumbsup:
  • Hot  28 replies
  • Hot  36 replies
  • 10 replies
