Oil weight temp range
3 replies to this topic
  • CBreaken
Posted August 20, 2004 - 12:29 PM
I was looking through the yamaha service manual for my 04 yz450f and found that yamaha specifies an oil weight range for USA and Canada,(20w-40 for temps above 40 and 10w-30 for temos below) and then a second oil weight range for the rest of the world,(tons of weights across a broad temp range with 10w-40 being the most versitile) whats up with that? Is this another EPA mandated deal?
Posted August 21, 2004 - 03:36 PM
It is an EPA deal. Has to do with wear reducers formerly found in SG oils, which are no longer in the current SJ/SL spec. Use a 10w-40 oil with a JASO grade MA. It's the equivalent of an SG with improvements. See my elaborate response on this subject in the recent thread "what kind of oil do you use?"
  • sirthumpalot
Posted August 21, 2004 - 04:31 PM
A side note; the Golden Spectro petrolium/synthetic blend is still classified SF/SG and is also listed as JASCO MA. I'm sure there are other oils that still fit this catagory.
Posted August 22, 2004 - 04:38 PM
True. Golden Spectra 10w-40 is what I use. Motorex makes JASO MA graded oils too, I hear.
  • 10 replies
  • Hot  36 replies
  • Hot  50 replies
  • Hot  47 replies
