Suspension setup for bigger dudes - recommendations?
7 replies to this topic
  • Shuffler
Posted August 19, 2004 - 01:25 PM
With all the gear on, plus Camelback, tools, tubes, etc., my rider weight is pushing 230lbs (I'm 195 buck naked). Should I be thinking about getting stiffer springs front and rear, and re-valving? The stock setup doesn't feel too bad, just wondering if it could be better. I'm familiar with RaceTech for the forks, but what about aftermarket springs for the rear?
  • Indy_WR450
Posted August 19, 2004 - 01:30 PM
stock or.48kg front springs and 5.6kg or 5.8kg rear spring. Revalve as needed. :thumbsup:
  • SXP
Posted August 19, 2004 - 04:34 PM
0.48 kg/mm front.... :thumbsup:
  • Hamish
Posted August 20, 2004 - 02:07 AM
I'm 200lbs starkers and just fitted a 5.8 rear spring. I kick myself for not doing it the day I bought the bike!
havent touched the front yet as I havent felt the need. When I get better at jumping I may have to step up to .48's.
I suggest you go over to the suspension forum. Those guys are so helpful and know everything about suspension tuning.
  • irtrouble
Posted March 31, 2005 - 01:22 PM
195?
Really, Shuffler? Really?
After Vegas?
I don't think so.
  • vmxr
Posted March 31, 2005 - 01:40 PM
I'm 195 and the .47s are excellent in the front. I went with the 5.6 in the rear, a little soft. Should have gone with the 5.8...
  • nevadaoutlaw
Posted March 31, 2005 - 03:15 PM
i am pushing 235 lbs. w/ gear on. Any suggestions on springs? Just making both front and rear 2 clicks harder helped so much. I have a 05 WR 450.
  • Victor Champion
Posted March 31, 2005 - 03:22 PM
I'm about the same size.
I just put 5.8 on the rear.
The front is being revalved with the stock springs (.46).
Should be perfect for you too.
I ride mostly desert with the ocassional 10' jump. :naughty:
