Clutch Problem, I think.
2 replies to this topic
  • Ernie_Taylor
Posted August 18, 2004 - 08:00 AM
IN the past I could alway pull in my clutch and roll the bike around in gear. It would seam that I can't do this any more with out butting my back into it.
I have tryed ajusting it at the clutch purch but with no luck. Does this mean I need a new clutch or pressure plates ?
  • Ernie_Taylor
Posted August 18, 2004 - 08:18 AM
I should add that it's a WR450 ,03 with only 2000 KM and I am not a heavy clutch user and I don't race. :thumbsup:
  • simch
Posted August 18, 2004 - 08:45 AM
mmmm< is it dragging when you ride it, ie does the bike pull when you are in gear with clutch lever pulled in? It may be the springs are getting a bit weaker? I belive you can get uprated springs and or collars for the WR. Not 100% sure though?
At 2k km it may be on its way out, depending on what terrain you ride on and how much use it gets?
