seat height on XL650
2 replies to this topic
  • drtbkjoe
Posted August 17, 2004 - 04:34 AM
Does anyone have any tips to lower the seat height by 2-3 inches on an '04 xl650? Does Kouba or storm make links for them?
Thanks
  • panzerpilot
Posted August 17, 2004 - 05:13 AM
TRY BAJA DESIGNS,I SEEM TO RECALL SEEING A LOWERING LINK IN THEIR CATALOG
  • hotwheels
Posted August 21, 2004 - 04:01 PM
You can lower the seat hite of the xr650l aprox. 1" to 2" for free. Turn the collar on the rear spring to remove almost all the preload on the spring (one turn from free spring), the locking collar won't thread on but I haven't had a problem. Slide the fork tubes up thru the triple clamps 1". This lowered the bike over 1" at the seat, for 0$. You can increase the rear spring preload to make the bike turn better but you will start to lose stability at speed, life is a compromise. You will need to modify the side stand to prevent tip over. File the stand where it contacts the tab on the frame so it moves further out when down, this is sort of cut and try to get the bike to sit safely on the stand. This you will have to do no matter how you lower the bike to prevent tip over when on the side stand. I see you live in FL. I ride alot in Ocala nat. forest, meet you at big scrub ? Good luck !
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  60 replies
  • 4 replies
Honda XR650L 2017
  • 0 reviews
