Y2K WR400 THROTTLE STOP EURO SPEC
3 replies to this topic
  • john_pearce
Posted June 21, 2001 - 01:49 PM
HI ALL
SORRY FOR POSTING ON THIS FREQUENT TOPIC ,
BUT ON MY EURO SPEC Y2K WR400 THE THROTTLE
ONLY TURNS A 1/4 TURN . I REMOVED THE THROTTLE STOP SCREW ( THE UPRIGHT ONE AT THE REAR OF THE CARB LOCTITED IN ), BUT IT DIDN'T
MAKE ANY DIFFERENCE ,THE THROTTLE STILL ONLY TURNS 1/4 TURN . CAN ANYONE ADVISE IF THE EURO SCREW IS ALREADY TO THE REQUIRED LENGTH AND THEREFORE DOES NOT REQUIRING TRIMMING. THE TOTAL LENGTH OF THE SCREW INCLUDING THE HEAD IS 23MM ,OR 17MM WITHOUT THE HEAD .I'VE PUT IT BACK IN AND THOUGHT I'D BETTER SEEK SOME GUIDANCE.
YOUR HELP IS APPRECIATED AS A BIT CONFUSED.
JOHN
PORTSMOUTH ENGLAND
  • Derek_Burns
Posted June 23, 2001 - 11:21 AM
Hi John,
I dont know if i can help you here, but maybe.
My mate has a 99 model WR, and his throttle stop was a kind of sleeved pin which was loctited over the end of the throttle stop screw, I just pulled and twisted it off with pliers. My 01 WR however didnt have a throttle stop at all. I'm not so sure what the score is on the 00 model, but surely it should be obvious exactly what is reducing your throttle movement when you look at the side of the carb? The easiest thing to do is to take off the carb and reduce the length of the stop until you can see that the throttle slide moves up enough to give full throttle.
good luck
Del
  • David_W
Posted June 26, 2001 - 05:28 AM
John
UK spec WR's have the shortened throttle stop from the YZ as standard. I found this out after spending £8 on the YZ bit. Doh!
'00 WR400F, YZ Timing, FMF Power Core IV2, Renthal Bars.
  • john_pearce
Posted June 26, 2001 - 09:54 PM
HI
DEREK / DAVID
I MANAGED TO TAKE THE RUBBER INTAKE OFF FROM
THE BACK OF THE CARB , AND NOTICED THAT ALTHOUGH YOU ONLY TWIST THE THROTTLE BACK 1/4
TURN THE THROTTLE SLIDE ACTUALLY GOES ALL
THE WAY UP . SO THERE WE ARE SORTED , THE
EURO BIKES HAVE THE YZ T/STOP .
I WASN'T REALLY LOOKING FOR EXTRA POWER
JUST CURIOUS WHAT THE SCORE WAS ( you know
what its like tinkering in the garage ).
THANKS FOR YOUR HELP LADS
JOHN
P.S. DEREK , HAD A LOOK AT F/EDDY RESULTS
WHAT WENT WRONG (CAN'T BE THE BIKE ) ?
