Fuel Screw - O-Ring / Washer Order
6 replies to this topic
  • V968231
Posted August 16, 2004 - 10:25 AM
Just putting my carb back together but cannot work out if the order of the Fuel Screw O-ring and Washer. The spring goes onto the Fuel Screw first I think, but does the metal washer go next or the rubber O-Ring:confused:
  • Jackazz
Posted August 16, 2004 - 11:19 AM
Maybe it's on here...
[image]http://parts.yamaha-motor.com/scripts/ImgServ.exe/convert?ilFN=d%3A%5Cinetpub%5Cempartweb%5CCatalog%20Data%5Cimages%5C02%5C0112%5C0010.TIF&ilSC=15&ilIV=0&ilBR=0&ilIF=G&ilRE=8[/image]
EDIT, okay, for some reason that did'nt work, even though it did when I pasted it into my Internerd Exploder address bar. Go to the link below & find the carb section for your bike.
From the Yamaha Online Parts Catalog.
  • V968231
Posted August 16, 2004 - 11:26 AM
I can't work it out from the diagram :thumbsup:
  • bikepilot
The o-ring must be the last thing you put on. The washer is there to keep the end of the spring from damaging the o-ring. If you look closely there is a sharper edge on the washer from when it was stamped out, I always like to face the sharp edge to the spring leaving the smooth side toward the o-ring, but it probably doesn't matter that much... :thumbsup:
  • V968231
Posted August 16, 2004 - 11:28 AM
Thanks :devil: :thumbsup:
  • bikepilot
Posted August 16, 2004 - 11:30 AM
No problem! :thumbsup:
  • Gadsen
Posted August 16, 2004 - 01:57 PM
The spring goes on first, followed by the flat washer, then the o-ring. :thumbsup:
