yz 400 motor knock
6 replies to this topic
  • hontrx265r
Posted August 15, 2004 - 02:43 PM
Just seeing if any of you have some ideas. I have a 99yz400 that I installed a 426 rod, cylinder bigbored to 96.5 (439cc)and a weiseco piston that I believe is 13:5:1 I started it and their is a horrible knock coming from what I believe to be the top end (possibly valves?) hitting the piston or something along that route any suggestions the head gaskets have also been doubled up. could the skirt be hitting something
  • DoctorRzed
Posted August 15, 2004 - 02:57 PM
I would check the valves, but I would think you need to run race gas in that beast.
  • hontrx265r
Posted August 15, 2004 - 02:58 PM
I'm running klotz 114 octane race gas
  • DoctorRzed
Posted August 15, 2004 - 03:00 PM
Whats the diff between the 426 rod and the 400?
  • Rich_Rohrich
Posted August 15, 2004 - 03:10 PM
The wrist pin size was increased by 1mm, otherwise it's the same.
You might want to start by verifying the cam timing is correct. If possible do it with a degree wheel to ensure that neither of the cam gears has moved from their original position on the cam.
Checking piston to valve clearance during assembly is also pretty important when you bump up the compression.
  • sirthumpalot
Posted August 16, 2004 - 12:48 AM
To check the piston/valve clearance, remove the head and put a very small amount of puddy on the piston where the valves are most likely to hit it. Assemble the motor and with the spark plug out SLOWLY spin it over. Remove the head and by looking at the puddy you can see if the piston and valves made contact.
That said, you've got a pre-01 engine. Before you check anything else, have you checked the key shaft on the counter balancer? A fairly common problem on the older bikes is that key will get worn and the gear gets loose on the shaft and from what I understand it can make quite a racket.
  • yz426onNOS
Posted August 16, 2004 - 01:20 PM
:thumbsup: :lol: A fellow Klotz user! :devil: :awww:
If it were your valves and the timing was off by one tooth. The valves would hit and bend, in most cases. Try race gas bro. Check the keyway, timing, and did you check all the measurements? You also need special head gaskets when running high comp. Motors as well as high octane gas.
