My 2002 YZ 426 is too tall for me!
5 replies to this topic
  • dirtbiker143
Posted August 15, 2004 - 02:21 PM
Anyone out there know if there's a lowering link available for the 2002 YZ 426? I need to drop the bike approximately 3/4" to 1".
Your help would be appreciated.
  • DoctorRzed
Posted August 15, 2004 - 03:04 PM
How tall are you?
  • Fastest1
Posted August 15, 2004 - 05:26 PM
Try Kouba. I believe they are at www.koubalink.com
  • Yak
Posted August 16, 2004 - 06:26 AM
There are a few options.. Im 5'7" and when I first got my 426 I thought it was going to be impossible to ride. My remedy for the time being was to shave out a little of the seat foam, similar to how a freestyle bike would look but not as extreme. The down side is that getting up on the tank for cornering isnt an option, too hard on the scrigg!
I run a full seat now, but the shaved seat really helped me learn without dumping it alot.
Also, You can run a hair more sag than optimal, maybe 110 mm. While running more sag you can also adjust the forks up in the clamps 5-10 mm.
  • Fastest1
Posted August 16, 2004 - 09:23 AM
You can also cut down the subframe where it mounts to the frame and reweld it(about 10mm), you will be able to leave the seat alone
  • YAMAKAZE
Posted August 16, 2004 - 09:54 AM
I had the same problem, you can raise the forks up in the clamps almost an inch. That made a huge difference in turning as well.
You could also take your riding boots to your local shoe repair shop and have them "Herman Munstered".....hehehe!
Bonzai :thumbsup:
