1987 xr600 bog
3 replies to this topic
  • al600
Posted August 15, 2004 - 03:15 AM
I recently purchased a 1987 xr600 for $600. It needs a little cosmetic work but doesnt run too bad. ONe problem I noticed was it has a slight hesitation when you snap the throttle. It has a K&N filter with supertrapp exhaust. Could this be a jetting problem? Any suggestions on where I should start first? Thanks.
  • truck6driver
Posted August 15, 2004 - 08:27 AM
Is the 87' a single carb or a dual carb? If it is a single carb the problem is common to the beast. The carb has a slide that uses engine vaccum to open it. If you remove the slide and drill the outside 2 holes to 5/32nds and shim the slide needle to .28 to .32 this will help greatly. Worked wonders on my XR650L. There are pictures of this procedure at a site I use www.xrlug@yahoogroups.com in the photos section. Good luck.
Ray
  • don87xr600
Posted August 15, 2004 - 04:08 PM
'87 is dual carb.
  • XR250rdr
Posted August 15, 2004 - 09:16 PM
Yep and the bog is a feature. Just dont whack the throttle open like that and it wont do it. I very rarely find the bog when I'm riding.
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
Washington
  • Hot  32 replies
  • 22 replies
  • Hot  186 replies
