83 xlr600 detonating
3 replies to this topic
  • 83xlr600
Posted August 14, 2004 - 09:46 PM
hi there
my 83 xlr600 detonates when under heavy load as in trying to accelerate from cruising in a higher gear or when pulling wheelies does anybody know wat the problem may be i run it on 91 octane fuel and it has a dpr8ea-9 which is the best ive tryed with it, it also starts and runs perfectly except under heavy load the noise is a heavy knocking like the piston trying to slap and was wondering if anyone had experienced this and had a fix for it thanks
Casey lyons
'83 xlr600
'79xr185
'79xls250
  • targetdrone
Posted August 15, 2004 - 09:31 PM
My first thought is to check your timing.
Has the bike just started doing this?
  • AzMtnThumper
Posted August 15, 2004 - 10:24 PM
I'd check the jetting first, sounds lean. You're on the right track a cooler spark plug does help.
  • 83xlr600
Posted August 16, 2004 - 10:04 PM
i have checked both cam and ignition timing and are all fine, it may be the mixture but would usualy lean out all the time not just under extreme load ill put a gas analyser on it to check jetting also i was going to run some avgas(avaiation fuel) in it to see if it runs better on a higher octane fuel as the head could have been machined before i bought it any other help or ideas would be much appreciated
thanks
casey lyons
  • 2 replies
  • 22 replies
  • Hot  35 replies
  • Hot  132 replies
  • 17 replies
