My front brakes wont work?
5 replies to this topic
  • DoctorRzed
Posted August 14, 2004 - 11:15 AM
I was at the track and lost it around a corner. It fell on the right side. Not a hard crash at all. I went to squeeze my front brakes and there was no pressure and the didnt work. There is no fluid leaking anywhere? If I got Air in the brake line whould it cause the loss of pressure?
  • Jeffro426
Posted August 14, 2004 - 11:44 AM
Check your calipers and make sure nothings binding, and try bleeding the brakes...no pressure in the breaks either means you got a nasty leak your not seeing, or a massive amount of air somewhere in there.
  • DoctorRzed
Posted August 14, 2004 - 12:22 PM
Ill have to go get some brake fluid. IfI do havea leak Ill get the lightspeed cr kit :thumbsup:
  • motocross15_3
Posted August 14, 2004 - 04:04 PM
bleed the brakes or they can be ceised up this happened to my old bike
  • yzf450jack
Posted August 14, 2004 - 06:11 PM
Try holding the lever in with tape for an hour or so it should come back add brake fluid if its low :thumbsup:
  • Fastest1
Posted August 14, 2004 - 06:50 PM
Reset your forks, they are probably tweaked.
  • 0 replies
  • Hot  28 replies
  • Hot  38 replies
  • Hot  50 replies
  • Hot  30 replies
