Helmet Visor Fix?
3 replies to this topic
  • RacerX
Posted June 21, 2001 - 05:32 AM
Have an HJC helmet that has one of the visor screws pulled out. I can kinda screw the screw in but the insert is basically stripped. Anyone have ideas on an easy fix for this problem?
  • *mike68*
Posted June 21, 2001 - 06:08 AM
A resin based epoxy may work
  • RacerX
Posted June 22, 2001 - 12:53 PM
The problem is with the threaded insert, it's stripped. I probably need a new insert but don't know where to get one. I'll use epoxy to install it though if/when I do find one. Any other ideas out there...
  • mcarp
Posted June 22, 2001 - 02:03 PM
If it's metal, JB Weld should do the trick...
