New shock springs?
3 replies to this topic
  • das_sey
Posted August 06, 2004 - 03:46 AM
Can someone tell me how difficult it is to put a new shock spring on my 03 WR450 and if it requires any special tools. I am pretty mechanically inclined. If you have any how-to instructions, that would be great. I need to put a stiffer spring on my bike.
Thanks,
  • PBDBLUE
Posted August 06, 2004 - 04:06 AM
Easy. Remove the shock. Start by backing off on the adjuster nut(s). Then remove the retainer ring at the other end and remove the spring. Reverse the procedure to assemble. I would set the spring length in the middle initially and then adjust the sag after you re-install it on the bike.
  • das_sey
Posted August 06, 2004 - 04:28 AM
Thanks for your help. I was not sure if you had to have a special tool to compress the spring to re-assemble.
Cheers
  • Hamish
Posted August 06, 2004 - 01:21 PM
you dont need any tools to compress the spring. You only need 10-15mm of preload(if u r outside of this range your shping rate is wrong) , and there is heaps more thread than that on the shock body. The only tool that comes in handy is a 'C spanner' to undo the shock nuts, but a hammer and large flat blade screwdriver works also. Just be careful that you don't nick the thread. I just got my shock serviced and fitted a 5.4KG spring. Just about to go out for a test ride.
