00 426 stalling in air
2 replies to this topic
  • Fyrnsmk
Posted August 02, 2004 - 04:52 PM
sup guys, ran into a problem this week at the track, bike kept stalling in the air when, i turned up the idle at the track and the problem went away, just want to know if this was the correct form of action, or if there is a hidden problem. Thanks! :thumbsup:
  • rws
Posted August 03, 2004 - 03:34 AM
man that's one of my biggest fears [at least while riding]. Are you doing any type of "acrobatics"? Whips? or anything that is putting the bike out of "normal" alignment?
Aside from a simple idle adjustment [which you've already done] I'm wondering if perhaps you have a clogged jet or carb in need of a little TLC [read "cleaning"].
Brainstorming here... could be you've already solved the issue with the idle adjustment.
  • John_Lorenz
Posted August 03, 2004 - 03:51 AM
When was the last time you did the following:
1: Clean Carb (Take Complete Apart)
2: Clean Air Filter
3: Change Plug
4: Adjust Valves
Look at this Thread Good info on the same issue
Stalling in mid air
  • 9 replies
  • On Yesterday, 06:20 PM
  • 0 replies
  • Hot  36 replies
