2000 YZ 426 coolant leaking out under water pump cover
6 replies to this topic
  • x654
Posted August 02, 2004 - 05:34 AM
coolant is leaking from bottom of water pump cover. have not taken apart yet... any idea what it may be???? 2000 yz426
  • YAMA455
Posted August 02, 2004 - 05:39 AM
Ya, that is a weep hole that lets you know that your impeller shaft seal has gone bad.
  • John_Lorenz
Posted August 02, 2004 - 05:40 AM
Sounds to me like a leak at the water pump cover leaking coolant. Good thing you asked. I would take a look at the impeller as well change the o rings while your at it. :devil: :thumbsup:
  • x654
Posted August 02, 2004 - 10:46 AM
Thanks Guys, just orderd new seals and bearings. hope it is all that is wrong. :thumbsup:
  • id250f
Posted August 02, 2004 - 02:53 PM
mine was probably just oil seals (03 450 ...) but I changed my bearing too ... bearing actually looked good when I changed it...a 'bit of a pain to get to.
  • Hank
Posted August 03, 2004 - 03:04 AM
You will be good to go once you replace them, been there done that..... Nice heads up move to notice the leakage... :thumbsup:
  • x654
Posted August 11, 2004 - 05:02 PM
:applause:just finished replacing both seals and the bearings, no problems. thanks for the info and all is well. now i just need more engine ice. :devil: thanks for the info all, it helped not going in blind. :thumbsup:
