Down hill backfire
4 replies to this topic
  • 450high
Posted August 02, 2004 - 12:58 AM
My 450 always backfire when i let the throttle back to idle going down hills.Is there any easy fix.I believe it is worse with a clean are filter ?.Any ideas would be greatly appreciated.
Dave
  • the426master
Posted August 02, 2004 - 01:49 AM
it is idling to lean adjust your idle mixture screw on the bottom of your carb :thumbsup:
  • Hank
Posted August 02, 2004 - 02:51 AM
Check out the Zip-Ty solution that replaces your origional screw with one that lets you adjust it with your fingers. They are sweeet.. :thumbsup:
  • PBDBLUE
Posted August 02, 2004 - 04:31 AM
If it takes more than 3 turns out on the screw to get rid of the popping put in the next larger pilot jet.
  • JVP
Posted August 02, 2004 - 07:15 AM
Besides turning your mixture screw out use a mix of race gas and premium to get the 95 octane rating. :thumbsup:
