vlave clearance xr 600 '92
2 replies to this topic
  • vincent1
Posted August 01, 2004 - 05:17 AM
Hello guys, can anyone tell me what the valve clearance should be (xr600, 1992)and how you adjust it? I've seen those 4 big nuts on the clylinder head, but how does this work? thanks in advance! :thumbsup:
  • don87xr600
Posted August 01, 2004 - 02:23 PM
intake .10 mm .004 inches
exhaust .12 mm .005 inches
  • MotoChris521
Posted August 01, 2004 - 03:59 PM
Four big nut's being the Valve cover caps?Piston needs to be at TDC on the comp.stroke,Insert feeler gauge between valve tip and tappet adjuster,should have slight drag when at right setting,one thou more should be tight(heavy drag)Good luck,practice makes perfect. :thumbsup:
  • 3 replies
  • 9 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
