00 yzf426 rear shock problem
7 replies to this topic
  • Canadanewbie
Posted July 28, 2004 - 08:00 PM
My rear shock suddenly stopped getting full range of motion.Is this common? I still have movement but it is not nearly what it used to be. Could this just be the bearings or is it more serious?
  • yz426onNOS
Posted July 28, 2004 - 08:39 PM
Is the rod bent?
  • felony
Posted July 29, 2004 - 08:48 AM
whens the last time you greased your supension linkage? :thumbsup:
  • Canadanewbie
Posted July 29, 2004 - 05:48 PM
Rod looks good ... It was suggested that maybe the Nitrogen needs recharge. I'm also checking all the linkage this weekend. I have the bike torn down to the subframe so far and nothing looks out of place but i haven't removed the shock yet.
  • Canadanewbie
Posted July 29, 2004 - 05:55 PM
I haven't done any in depth lubing, only superficial to this point. I'll be examining it all this weekend :thumbsup:
  • Ga426owner
Posted July 30, 2004 - 03:40 AM
lubing is critical - check the shock bushing - it is probably shot -
Nitrogen doesn't just leak out without major issue - may need a complete rebuild if that is the case - great chance to revalve if this is the case. Link for bushings:
http://www.pivotworks.com
  • Canadanewbie
Posted August 01, 2004 - 02:02 PM
Got the shock out it looks good. The swing arm seems to be the real problem. It has good motion from the primary link at the rear of the engine once the lower connecting rod is detached from the frame. Do the lower bearings wear out often? Should all the linkage be free moving? :thumbsup:
  • RogerDedrick
Posted August 02, 2004 - 03:19 AM
Depending on your riding conditions (My riding conditions are mainly mud in the northeast) I try to clean and lube them twice a year. It looks like they might live about two seasons with that maintance plan. They should be free moving.
Roger
