radiator sealant?
4 replies to this topic
  • Shane_Bettin
Posted July 27, 2004 - 06:06 PM
anyone have any experience with using rad sealant for a leaking rad. i crashed my bike real good and the left rad is leaking from somewhere near the bottom. or is there any stuff out there that is recommended for these kind of leaks. im talking about the kind of stuff that you mix in your coolant.
  • Jeffro426
Posted July 27, 2004 - 06:44 PM
I would recommend against using any kind of sealant or the likes...i would only use that stuff for emergencies or to get me to the nearest shop to get it fixed. Most sealant seems to seal/clog up other things too...not just your hole. With that said, your best bet would be to send your radiators off to Myler...they have a super quick turn around, do top notch work, and are very fairly priced...espeically considering what a new radiator costs!!
  • Maddog542
Posted July 27, 2004 - 07:10 PM
Send it to Mylers. It may not be pretty in the cooling fins still when you get it back, but it will be fully functional and straight. New radiators for the YZ or WR are about $300 per side. Invest in a pair of guards and or braces.
  • steg211
Posted July 28, 2004 - 04:53 AM
Find out exactly where it's leaking from. I had a wr426 that I crashed and tore the lower hose mount half off of. I took it to a local rad. shop and he put some type of high temp epoxy on it for like $30. It worked great, but I didn't damage any of the cooling flues that run vertically. If you did, then your local shop is probably not gonna be able to do anything with it. Better send it to where these other guys who know recommend.
hope this helps.
  • Fly-nBri
Posted July 28, 2004 - 05:24 AM
Send it to Myler's here in SLC and do not use the epoxy. You want it welded and pressure checked, which Terry Myler does,and not epoxied. Terry is very reasonable also. Fixed mine for $30 OTD. :thumbsup: He will also lightly sand blast it when finished and paint it for ya to look good as new!
You will not be disappointed!
  • 0 replies
  • Hot  79 replies
Need help by Goforaride
  • Hot  68 replies
  • 9 replies
  • Hot  28 replies
