WR450 DENTED HEADPIPE?
5 replies to this topic
  • mntmayfly
Posted July 26, 2004 - 03:16 PM
i dented my headpipe over the weekend, can i expect any ill effects? its dented at the bend about 1/2 the pipe or less? :thumbsup:
  • Indy_WR450
Posted July 26, 2004 - 03:41 PM
Repair it and it will collapse again real soon. Replace it with any SS aftermarket header and avoid the Ti stuff that does not hold up! :thumbsup:
  • mntmayfly
Posted July 27, 2004 - 07:02 AM
my real question is can i rid eit like this until get a new one? :thumbsup:
  • Indy_WR450
Posted July 27, 2004 - 07:20 AM
Yes you can ride it for now without to much issues.
  • PBDBLUE
Posted July 27, 2004 - 07:54 AM
I just repaired a crinked 450 pipe recently. It was mashed up pretty bad and I was able to "re-expand" it by capping the ends and applying compressed air inside (it only needed about 5 - 10 psi) while heating it slowly with an acetylene torch. It didn't come out perfect but certainly very servicable. Yours doesn't sound half as bad. If you have access to a gas welder you might give it a try.
  • mntmayfly
Posted July 27, 2004 - 10:37 AM
i dont have access to any flames or explosives, that would be scary, ahh.. what i could do with a torch! i might give the old water in the pipe and freeze it trick a try?
thanks guys! :thumbsup:
