Engine Builder Wanted
13 replies to this topic
  • Doug_Caldwell
Posted July 26, 2004 - 05:52 AM
I have been looking into sending out one of my motors for modification. I want to have the cases matched, crank trued, head done (possibly bigger valves), etc. But I have only found a couple of places. I was wondering if anyone has had a good experience with anyone. Also I am looking for other internal engine parts to look into.
I am also looking for a Big Bore Kit (475cc - 500cc). But that is not as high on my list of things to do. I want to be able to have a Big Bore cylinder and a Standard cylinder.
Any help would be great.
  • YZDAD1
Posted July 26, 2004 - 06:31 AM
What is your application and budget?
  • Doug_Caldwell
Posted July 26, 2004 - 06:45 AM
Motocross. I race the Open A and +25A Classes. I would like to have the complete motor done for around $800 -$1000.
I am trying to get a little more reliability and a little more power across the board. I like to have plenty of low-end power, so I can just role it on. But I really like to rev it rather than shift it.
I have a really good set-up right now I think (without motor work). I am running a Big Gun Signature Series Pipe, 50-tooth rear sprocket, and Hinson Clutch. Other than that the drive tran is stock (or stock equivalent).
  • SFO
Posted July 26, 2004 - 01:55 PM
http://www.eric-gorr.com/
  • SUnruh
Posted July 26, 2004 - 02:21 PM
what sfo said!
for the price, i don't think you can beat him. :thumbsup:
  • YZDAD1
Posted July 26, 2004 - 02:59 PM
PM'd you.
  • Ron Hamp
Posted July 27, 2004 - 01:56 PM
you might get a big bore kit and have it installed for around $1000 but that would be about it
  • DoctorRzed
Posted July 27, 2004 - 03:36 PM
I have seen ?470? big bore kits for $300 w/piston and gaskets on ebay. But you have to send them your own cylinder. I believe it comes w/ a wiseco piston.
  • Doug_Caldwell
Posted July 28, 2004 - 03:28 AM
I should have been a little clearer with my question. I am a full-time mechanic, and used to work as a tech at a local dealership. I can disassemble and reassemble the engine with little difficulty. I am mostly looking for suggestions on internal parts to upgrade and someone with the experience to perform the machine work modifications.
For example, I would like to have the head ported/flowed. I would take the head off and send it in. If I need new valves/seats/seals, I would send them along with the head. If I were upgrading cams, I would just install them myself.
As far as the big bore goes, I would either buy another brand new Yamaha cylinder and have it bored/plated, or I would buy a cylinder off the internet already bored/plated. I am not worried about the Big Bore Kit. I just wanted some input on where is the best place to talk to. (I have looked at Max Power’s and Eric Gorr’s websites)
  • SFO
Posted July 28, 2004 - 02:01 PM
Eric Gorr will definitely give you your moneys worth.
Give him a call or post on DRN.
  • FFRacing79
Posted July 28, 2004 - 02:04 PM
My suggestion would be to stay away from the bigbores...reliability has been a problem. We are getting more HP from a good running 450 than the 500 bigbores anyway, and reliability has been really good.
  • yz426onNOS
Posted July 28, 2004 - 03:20 PM
I'm bored to 450 with 13.5.1 and reliability has never been beter. There perfectly fine if you do it right and take care of it. Hot cam's will run you about $300. Porting will be about $300. Good complete pipe about $800. Airfilter $25. Bigbore and high compression will be more. Then you have to factor in the race gass you will need.
  • FFRacing79
Posted July 28, 2004 - 04:16 PM
Hmmm...60 plus HP from a stock bore 450...been running the same lower end for 2 years...you get what from your BigBore?
  • yz426onNOS
Posted July 28, 2004 - 04:35 PM
Never dynode. I have had the same low end for 5 years. Run’s on race gas. It was done right. No major failures. I ride it hard! I have a whole list of mod's:
-13.5.1
-450 bore
-ported and polished
-full exhaust (header and slip on)
-air filter
-hotcams
-air box mods
-carburetor mods
Soon to come:
-larger bore
-stroker
-larger valves
-alcohol
-NOS
-all the good ol micro polishing and matching too.
  • On January 15, 2017
  • Hot  113 replies
  • Hot  36 replies
