Coolant mixture
5 replies to this topic
  • WR426madness
Posted July 24, 2004 - 07:02 PM
What coolant ratio do you guys use in your WR's & YZ's ?
  • luke_n
Posted July 24, 2004 - 07:23 PM
Use what the brand you are using recommends.
Remember that coolant doesnt actually cool very well but is simply there to prevent the water from boiling or freezing and prevent corrosion. The water is what actually transfers most of the heat.
To answer the question though, 40% coolant 60% Water
  • Rich_in_Orlando
Posted July 25, 2004 - 02:18 PM
  • Indy_WR450
Posted July 25, 2004 - 03:00 PM
50/50 distilled water/antifreeze
  • TallBoysWRF
Posted July 26, 2004 - 06:21 AM
same
  • Treebark
Posted July 26, 2004 - 09:03 AM
I agree with luken, as hot as these engines run water is what provides the majority heat transfer and if not running in low temps Id run 40/60.
