Any WR400's with FMF Powerbomb header and JD jetting?
3 replies to this topic
  • WRider995
Posted July 24, 2004 - 02:23 PM
Need a little jetting advice for my WR which has an FMF Powerbomb. Blue needle in 3rd position is coughing at about 1/3 throttle. I'm at about 700ft above sea level.
:thumbsup:
  • The_Missile
Posted July 26, 2004 - 12:53 AM
That would be me.
I will look into my carb settings, but basically they are stock all round except the needle and the
main jet which is a 168 I think. Dont look at my signature, its not updated.
I run a powerbomb + CRD (french < 94dB) pipe which is not as free flowing as it could be!
I also ride a little higher than you though 1800 feet to 4000
  • R_Little
Posted July 26, 2004 - 07:22 AM
Ive have the same setup as you.
I rode last weekend at about 2-3000ft and noticed the same coughing as you. I think its a little rich.
My main is a 168 and I'm running the blue needle. I gotta check the clip. 3 or 4 but don't remember. I use a power now so my pilot is a 40.
I'm going to change to the red needle and see what happens.
  • kirkw
Posted July 26, 2004 - 12:47 PM
below are my settings. I am stock other than what is specified below. Seems perfectly dialed for about 1000 feet and 70 degrees. Hope that helps...
