rear alignment
9 replies to this topic
  • geeeorge
Posted July 22, 2004 - 01:06 PM
my rear tire keeps rubbing my exhaust when i do small jumps or even whoops i know this is not supposed to happen, is there a way to move the swing arm a little bit to the left. If anyone has any ideas how to fix the problem please let me know.
  • yzwiley
Posted July 22, 2004 - 01:32 PM
There's no way to move the swingarm.
Your problem is most likely a bent subframe.
  • Wyatt
Posted July 23, 2004 - 03:41 AM
Yeah......what he said
  • John_Lorenz
Posted July 23, 2004 - 03:56 AM
What he said about what he said :thumbsup: and raise it a Ditto
  • YAMAKAZE
Posted July 23, 2004 - 07:41 AM
My subframe is Not bent and my FMF T-4 rubbed the inside sticker off from day one....
Hmmmmmmm
Bonzai :thumbsup:
  • John_Lorenz
Posted July 23, 2004 - 07:47 AM
Ok then What he said :thumbsup:
  • TimFurryBalls
Try putting a couple of washers against your subframe to move the exhaust out a bit. . .
  • Wyatt
Posted July 23, 2004 - 09:21 AM
what he said...........
  • jmw00
Posted July 23, 2004 - 10:33 AM
Yes, what all of those guys said, but just for your info... I am not sure what cc bike you have but there is a subframe on ebay for 400, 426 for a buy it now price of $60 and another that bid price is only $30 so far.. :thumbsup: if it turns out to be your subframe
  • Hank
Posted July 28, 2004 - 07:57 AM
There is suppost to be a quarter inch spacer that sits on the inside of the harness that holds the pipe. make sure that is there, i know if you go down you will also have that harness smash in a bit, if you undo the rear harness what ever you want to call it that pipe should be able to move right or left a couple inches, if it will not move right you might have a bent pipe forcing it to far to the left... anyway been there done that I went down and had the bending to do to get it to clear the tire... Unless you are running an unreal wide tire... stock is 90/110 anything bigger thatn 90/120 might rub ya ... not in a good way... :thumbsup:
