removing down tube oil screen?
3 replies to this topic
  • xrbrp
Posted July 21, 2004 - 08:18 AM
Do I need to remove the inlet and outlet pipe assembly just to clean the down tube oil screen? or can I remove the bolt and chage the screen.
The service manual indicates I have to remove the entire assembly. does anybody do it differently?
  • Kritter
Posted July 21, 2004 - 10:14 AM
pull out the bolt that secures the banjo in and once you hace that out you can get a socket on the bolt that hold the screen on. Be sure no to lose the crush washer.
I was just told about the screen the other day so I figured I would check it out. I was unaware of location and thought I was told it was on teh inlet from teh oil reservoir so after I take off the coolant hose inlet to get access to the hose fitting...I realize there is no filter there and now have coolant all over the place...
Oh well, guess I shoulda checked the manual. My screen had hardly anythign on it and has maybe 500 -800 miles on it with oil changes maybe every 100-150 miles.
  • xrbrp
Posted July 21, 2004 - 11:02 AM
thanks, I do not have to take the whole assembly off then, just the bolt and screen.
  • mikekay
Posted July 22, 2004 - 07:22 PM
Remeber--theres another, second screen to be cleaned once in awhile...
  • Hot  186 replies
  • Hot  35 replies
  • 3 replies
  • 17 replies
