Important: Grey Wire test on a WR426 test?
43 replies to this topic
  • Ga426owner
Posted June 07, 2001 - 02:47 PM
Has anyone tried to disconnect the Grey CDI mapping wire under the gas tank at the black dbl connector? This seems to have helped eleviate the mid range bog that is noticable to me on my 426 & to the owners of 2001 WR250's.
My bike is out of town til Sunday, so I can not check to see if this works/applies to the 426. For more info check the WR250 forum, under "what is wrong with the wr's"
I need some feedback asap. Thanks
This only will apply to US-spec WR's, not sure about 1999-2000 WR400's.
The wire is solid grey, next to the striped wire.
  • tonymontana
Posted June 07, 2001 - 04:11 PM
For what it is worth, I was told that the ignition retards in the mid range for noise emission tests. I am from Australia, and will chech if mine has a grey wire. Maybe that is what the grey wire does.
Tony Montana
  • Guest_Guest_*
Posted June 08, 2001 - 04:04 AM
Ooooohhhh, sounds very interesting. Keep us posted.
  • finglan
Posted June 08, 2001 - 05:01 AM
Did mine last night and took it on the road for a two mile ride. The studder at about 50mph at steady throttle was gone. Too short of a test to tell for sure. I am riding on Sat. will let you know how it goes.
  • olson_jr
Posted June 08, 2001 - 05:17 AM
This shouldn't be too hard to verify. Put a tach and a timing light on your bike. Find the RPM range that you think the timing is being retarded and check the timing. Then disconnect the grey wire and recheck the timing at that RPM. You should find that the ignition timing (or advance as it is sometimes called) is different with the wire disconnected.
If you don't have a timing light you could have a buddy hold the throttle at the RPM you think is flat and just connect and disconnect the grey wire. You should be able to hear a difference in the engine as the timing changes. You might even be able to get to the RPM range you need to check with the idle adjuster, then you don't need anyone holding the throttle and you remove one variable from your test.
I've got a Canadian 2000 WR400 so I don't think I have this grey wire.
Since I'm hobbling around in a knee splint instead of riding for the next couple of weeks I will try to take a look at my bike and run this test if I have the wire.
  • mcarp
Posted June 08, 2001 - 05:18 AM
Isn't this the rev limiter wire? I'm not unplugging mine, floating valves are not worth it!
Jetting should be able to solve the mid range flatspot, IMHO. Maybe not, though, huh?
  • TheBOS
Posted June 08, 2001 - 05:56 AM
Check out the thread on the 250f side, the rev limiter still functions with the wire disconnected. It seems pretty safe to try out because the Aussie bikes come stock with the wire disconnected - you can actually see this in the wr250f manual.
-Brett
  • tonymontana
Posted June 08, 2001 - 06:11 AM
Hey Olson
Check your wiring diagram, my Australin model 01 wr426 has the grey wire and as far as I know the Canadian and Australian models are the same. I will disconnect mine for a ride on monday ( public holiday in the colonies for her Majesty's birthday ).
I'll keep you posted.
Damn the torpedoes full steam ahead
Tony Montana
  • Ga426owner
Posted June 08, 2001 - 06:17 AM
You can see the same thing in the WR426 manuel.
Mcarp, the problem is this: jetting does not fix this issue, there is a issue because the grey wire (only on US version)was installed to change the rev limiter in order to pass emission test for noice or dirty air. What it does is trick the CDI unit, effecting midrange, causing lack of full power in the powerband.
There is no reason to think that by unplugging this wire that damage will occur. Why? Because all other non-US WR's don't have the wire.
The WR250 post explains this in full detail.
Your choice to be cautious, my choice to make my WR run like it is intended to.
  • mcarp
Posted June 08, 2001 - 08:21 AM
GA-
Thanks for educating me on this. Seems like there's no real risk afterall. I was not aware the non-US bikes DO NOT have this feature, which I agree-tells me it's OK to unplug it.
Cool...I may just try it, although I do not seem to have any hesitation issues...
  • James_Dean
Posted June 08, 2001 - 08:52 AM
The '00 WR400 wiring diagram in the manual shows this wire terminates at the connector from the CDI. It does not! The grey wire continues into the wiring harness at the connector to an unknown termination point.
Question is, What does the grey wire connect to?.............. (See below)
More to investigate.
[This message has been edited by James Dean (edited 06-08-2001).]
  • Ga426owner
Posted June 08, 2001 - 10:59 AM
James Dean, in the US 2001 WR426 manuel, you have the grey wire coming off the "B" line from both the 6connector(O:B:Sb:L:Y:B/L) to the CDI unit(left) & the sparkplug/ignition coil(Right). Both the Gy(grey) & the B(black)wire split off of "B" line, the grey going to the dual or (Gy:B/W)wires to the (B/W:Gy)connector which is the dual black connector back to the CDI unit. The "B" wire goes to the Engine stop button looping back to the black dual connector as "B/W" to the CDI unit.
On the non-US bikes the 6connector wiring is different with "Sb"(skyblue) wire taking the place of the L/W (Blue/white). I wonder why this is?
I know why the Gy(grey)for US -- emissions compared to the non-US (X:B/W)*Except for USA
James, I know this is confusing w/o a drawing, but is this the same on your 00WR400???
You should see the same benefit unconnecting the Gy from the dual connector as the rest of us if this is the same. Does anyone have a US 99WR400 manuel to check this???
  • Rich_in_Orlando
Posted June 08, 2001 - 11:28 AM
My engine's still in pieces, but I should have it running by next weekend. And I, too have been plagued with that annoying 50 mph stutter. Jetting changes have made it marginally better but haven't fixed it. I can't wait to get up and running again to see the difference with the gray wire disconnected.
  • James_Dean
Posted June 08, 2001 - 12:15 PM
Noted above: The '00WR400 wiring diagram in the manual does not match the bike.
The gray wire off the CDI is visible going into the wiring harness. There are no other gray wires ANYWHERE coming out of the wiring harness. All the wiring harness plugs were disconnected and the gray wire only has connectivity to the BLACK ground wire at the coil. The CDI also has a black wire which is grounded at the engine via the 6 wire plug.
So... Why would the CDI need 2 wires of different colors both grounded, one to the frame and one to the engine?? :)
More to research.
  • MN_Kevin
Posted June 08, 2001 - 12:40 PM
Mr. Georgia,
My '99 wiring appears to be identical to your 2001 bike.
'99 WZ/YR (you choose!) with ALL YZ mods, de-octopused, DSP Doug Henry airbox w/ velocity stack, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, forked over by Pro-Action (and then fixed by me), OEM YZ tank, IMS YZ seat, carb mods by Jim Dean, Andy in OZ, & Sir "Taffy" from Jolly Old England, AMA, NESC, and I use MOBIL 1 Oil, with ZERO problems.
  • MotoGreg
Posted June 08, 2001 - 05:12 PM
I just read through all the posts on that topic on the WR250 board so I went down to the garage and checked my bike. Mine is a '99 Canadian WR400 and the grey wire comes out of the CDI harness and goes to the black two wire connector and ends there. On the other side of the connector it is blocked off and there is no more grey wire. This must be a US model restriction only. I have briefly rode a couple US model WR's and they are soft through the midrange, my bike rips hard through the mid and keeps pulling hard all the way up to the rev limiter. If I had a US model I'd unplug this in a heartbeat and try it out.
Make sure you have the correct wire. On the harness coming out of the black CDI box there are three connectors. One of them is black with only two wires in it. One of the wires is black and the other is grey. The grey wire is the one.
'92 GSXR 7/11 (But I never ride it so you should buy it...)
'99 YZ400F 'cause thumpers rule and two strokes drool!
  • Rich_in_Orlando
Posted June 08, 2001 - 06:43 PM
Regarding my 99, I concur with NH Kevin.
  • James_Dean
Posted June 08, 2001 - 07:17 PM
Well, hope my CDI doesn't leave me stranded. A 60-80 mile ride is planned for tomorrow and it is disconnected. :)
Ga426owner, every indication is your description matches the wiring on my bike. I understand your posting after reviewing it and the wiring diagram.
The short test run feels like there may be more power. I need some wide open spaces to give it a good test.
James
  • Bruce_in_Phoenix
Posted June 09, 2001 - 09:18 PM
Cool now we can splice into the CDI and put a switch on the handlebars and have two settings like the Husaberg and KTM guys. Thrill me with rapture! If it gives me more boost, snip and it stays that way. This is the factories way of gaining an extra couple of ponies on the rest of us without works parts? Who knows. Somebody else find me 5 more horsepower for free. What else can I unplug?
  • Guest_Guest_*
Posted June 09, 2001 - 10:31 AM
ANy one have access to a dyno machine? it would be very interesting to see the diff this mod makes.
come to think of it, a dyno sheet on any non-US model that someone has would do it.
I wonder if the HP that Yamaha quotes is for the US or NON-US model?
I also wonder if the total max rev HP is effected since this was a mid range fix. Hmmm
Whether we get the answer from a dyno machine or not. I have done this mod and feel a big difference. I had not done any jetting previous to this though. So I would imagine that a bike that had made some improvement from jetting would not see as drastic a result as me.
mike
