Will a YZ400 Carb go staight onto a WR400F
7 replies to this topic
  • V968231
Posted July 19, 2004 - 05:06 AM
Can you kind people tell me if a 1998 YZ400 Carburettor will fit straight onto a 1998 WR400F?
Will I need any additional bits?
Will I need to disconnect anything such as the Throttle Position Sensor?
Is ther any reason why I should not fit this carb to a WR engine :thumbsup:
  • R_Little
Posted July 19, 2004 - 07:05 AM
The yz carb will fit perfectly.
The wr carb has an aircut valve for EPA purposes. Many guys remove it anyway.
  • dkwok
Posted July 20, 2004 - 12:24 PM
can u pls tell me where is the aircut off valve& how to close it?
thanks.
  • The_Missile
Posted July 26, 2004 - 01:13 AM
the acv on the old 98 and 99 carbs was called the octopus. you need to remove it.
  • V968231
Posted July 26, 2004 - 02:54 AM
What is the Octopus and where can I find it?
  • The_Missile
Posted July 26, 2004 - 03:22 AM
Its a mess of pipes on the left hand side of the carb. Pull em all off and block the remaining holes with a bung.
Hook up the hot start to the tube on the cylindder head
  • V968231
Posted July 26, 2004 - 03:37 AM
Is there detailed instructions for this Mod anywhere? :thumbsup:
  • tcmII
Posted July 26, 2004 - 07:09 AM
check out "www.thumperfaq.com" or this forum. You should be able to find all of the info you need. Also keep in mind that a number of posts have indicated that you need to change your pilot air jet when de-octopussing" the carb.
