Help!!!!!!!!!!!!!!
4 replies to this topic
  • dman1979
Posted August 15, 2002 - 04:13 PM
Well I was changing my oil this evening in my 2002 YZ 426 and noticed I had a problem when I went to put my oil drain bolt back in the crank case. There was a small piece of aluminum on the bottom of the bolt toward the head. So I removed the metal and tried to thread the bolt back in and found out that my threads are probably stripped in the crank case. I couldn't tighten the bolt all the way up. So I took the gaskett off to see if the bolt would snug up without it and it did. I need to know what the best way to fix this problem. I would like to also know how reliable it will be in the future once i get it fixed.
  • DaveJ
Posted August 15, 2002 - 05:48 PM
dman,
Check out the other current post by Mike Dean on this subject. Good tips there.
DaveJ
  • John_H
Posted August 15, 2002 - 06:07 PM
Not sure if you're talking about the drain bolt on the bottom or the one on the side case. Mine was on the side case. I bought a tap and die. Re-tapped the hole and ran the drain bolt through the die. Been fine ever since. If its not too messed up this might work. :)
[ August 15, 2002: Message edited by: John H ]
  • dman1979
Posted August 15, 2002 - 06:50 PM
Its the drain bolt on the bottom of the case.
  • sirthumpalot
Posted August 16, 2002 - 01:10 AM
If it's not bad then you might be able to clean it out with a tap like John said. If you try to fix it then you're likely going to have to drill it out anyway so I say give the tap a shot first.
