cam timing help
3 replies to this topic
  • trunkmonkey55
Posted July 17, 2004 - 01:03 PM
if my cam chain skips cam teeth will my timing be off
:thumbsup:
  • bushy
Posted July 17, 2004 - 01:09 PM
yes
If you cam chain is skipping teeth then your cam chain tensioner has retracted itself, or your cam chain is worn. Neither are expensive to replace, but the repair if you dont replace will be expensive.
  • trunkmonkey55
Posted July 17, 2004 - 01:20 PM
How do I retime My bike
  • terrymc
Posted July 17, 2004 - 04:48 PM
The manual does a really good job of explaining how to do that, but basically, you get the bike to TDC and line up the marks on the flywheel (in plastic hole by your left foot) and the cam. The marks are on the cam to show you where to line things up.
