Oil From breather Hose??
6 replies to this topic
  • AZ918MAN
Posted August 13, 2002 - 09:15 PM
Hey I was just wondering if its normal to get a little spot of oil from the breather hose??? I have been noticing that my bike has been blowing a little oil from the breather hose. I have been changing the oil when the bike is warm and putting 1750cc's of oil and a new filter in ever time i change it. Just hoping its not anything major. could it be valves out of adjustment? or????
  • HaremScarem
Posted August 13, 2002 - 10:43 PM
It's normal to get a drop or two. I would be more concerned if I did'nt see any overflow. :)
  • AZ918MAN
Posted August 14, 2002 - 12:00 PM
yeah but i am getting more than a few drops.
  • AZ918MAN
Posted August 14, 2002 - 12:01 PM
  • yznvegas
Posted August 14, 2002 - 12:26 PM
It's normal, the harder you ride, the more will come out, no worries.
  • skthom2320
Posted August 14, 2002 - 03:10 PM
If you are putting 1750 cc in each time you change the oil and filter, you WILL get more than a few drops. That is how much you should put into a completely dry engine.
I use 1650 cc for an oil/filter change. Then I check it the next time I run it.
Works for me.
  • Boit
Posted August 16, 2002 - 04:46 AM
Yep ,it's normal. Plus, sometimes it will spooge out a little more than at other times. Mine seems to run with the humidity. The higher the humidity, the frothier the spooge, and more of it.
  • Hot  30 replies
  • 10 replies
  • Hot  38 replies
  • Hot  50 replies
