FOOTPEG MOD??
28 replies to this topic
  • AZ918MAN
Posted August 13, 2002 - 12:40 PM
Can someone tell me about the footpeg mod or how to do it??
  • BrandonW
Posted August 13, 2002 - 01:48 PM
After you remove the pegs, you will see a spacer-type "barrel" that positions the peg upwards and to the front of the mounting brackets. Take a hacksaw and cut that barrel off. Now, weld the barrel back on the peg, but position it so the peg will be positioned down and away in the brackets. This is all much simpler looking at it as opposed to describing it.
Some of the engineer types in here have said that it is imperative that you weld the barrel back on, so I did.
If you have any more questions, I can probably post a picture tomorrow.
Good luck!
Brandon
  • novajunkee
Posted August 13, 2002 - 04:10 PM
Why do you have to weld the spacer back on the top?
  • yamaha.dude
Posted August 13, 2002 - 06:29 PM
Weld the spacer back on, even just tacked in a couple of places - it is much stronger and less stress on the pin.
The other thing you need to do to complete this mod is the swap the springs from left side to right side and vice versa...
David
[ August 13, 2002: Message edited by: yamaha.dude ]
  • DaveJ
Posted August 13, 2002 - 07:32 PM
I don't have my factory pegs anymore, but I don't remember anything being wrong that warrants a hack.
What's up?
DaveJ
  • AZ918MAN
Posted August 13, 2002 - 08:59 PM
Yeah it would be great if you could post a picture for me. I weld so there is no problem doing that just want to be sure its done right. also anyone know of any aftermarket pegs that lower the position?
  • BigDesto
Posted August 14, 2002 - 05:54 AM
Save your money and do the mod to your stock pegs!
Cut the barrels of the bottom of the pegs,now weld them to the top of the pegs,and swap springs. By doing this you have dropped and moved the pegs back about 1/2".
  • John_Lorenz
Posted August 14, 2002 - 06:07 AM
as Brandom noted the pegs once removed need to have the spacer hack sawed off.
Once this is done do the following
<ul type="square">[*]de-burr all edges around the spacer and peg (Effectivly)[*]No Need to weld[*]grease heavly -- Pin and Inside of Spacer / Peg[*]Springs now have to be swapped right to left side[*]Enjoy the 1/2 inch back and 1/2 inch down position[/list]
This was in my opinion the best mod for ergo's I made. I am a tall rider and my feet are huge, they used to get caught up in the shifter whil standing not any more.
You will have to adjust your back brake though.
Someone also had posted Pics do a search on peg mod
Here is the orig link and a pic
http://www.thumperta...ic&f=6&t=005134.
[ August 14, 2002: Message edited by: E.G.O.**** ]
  • Shawn_Mc
Posted August 14, 2002 - 10:32 AM
Anybody have any idea how to cut a stainless steel IMS peg? 24 hacksaw blades is not a good answer either.
I dont know if this happens to anyone else, but I have accidently hit the rear brake going into more than one set of woops. This is a very bad idea, and Ive wanted to move the brake forward about an inch ever since I got this bike. If you look straight down on the bike, the shifter is about an inch further foward than the brake. My Honda has them in the same place, which make sense to me.
  • John_Lorenz
Posted August 14, 2002 - 10:35 AM
Shawn
The only way your gonna cut stainless is to bring it to a machine shop unless you know someone with a small band saw.
You might try a dremal with a bunch of the fine fiber cutting wheels....
  • beezer
Posted August 14, 2002 - 10:48 AM
Hardware stores sell carbide impregnated hack saw blades.
They cut through almost anything.
I use them in my shop to cut hardened steel.
  • AZ918MAN
Posted August 15, 2002 - 08:58 AM
Thanks to everyone. Got the mod done but havent got the chance to try it. Hurt my back doing a backflip on a BMX bike. oh well "To be old and wise, you must first be young and stupid"
  • Hick
Posted August 15, 2002 - 09:38 PM
A chop saw will work, but it is still a bit tedious. I would think a band saw would only work w/ a carbide blade or something harder than a standard steel blade.
How does the right side IMS peg get along w/ the kick starter? I had a set of Pro Circuit pegs but took them off because it looked like I was just going to gouge a crater in my starter and eventually break it in half. Instead of hitting a squared-up pad the starter hit the sharp edge of the peg. I’d like to try those IMS pegs but I’m wary of what they will do to the kick starter.
  • BigDesto
Posted August 15, 2002 - 12:42 PM
Hick,after doing the mod,i noticed that the kick starter was hitting a creating a a big dent(gouge)
i got a piece of rubber fuel line that barely fit over the kickstarter and worked it down to where it was hitting, now the rubber is taking blow. It will wear down someday,then put another on.I've also been trying not to kick it so hard.If it's in the sweet spot,you can kick it easy without hitting the kickstarter.
  • John407
Posted April 30, 2003 - 08:55 PM
Tried out the footpeg mod today. It's a great! More leg room and lets you stretch out over the back of the bike. Thanks guys. I did weld the spacer back on, I see some guys didn't. Thanks again.
  • Fastest1
Posted May 01, 2003 - 03:50 AM
I was weighing 255lbs and I never welded the spacer back on with no failures yet. The pins are straight even after much abuse. :)
  • Chris_in_the_Mojave
Posted May 01, 2003 - 05:00 AM
I did the mod on my IMS Pro Series, I didn't have any trouble cutting them with a hacksaw. I didn't reweld the barrels...but I may after reading the comments here. :D
IMS and Fastway both do. I ordered a set of IMS Pro Series lowered for my 450( the set I cut are on my 250). They came ready to go, just pull the old pegs and swap the springs! :)
  • yz007f
Posted May 01, 2003 - 05:21 AM
I have a few rides on my cut foot pegs without them welded. The pins seem fine without any bending at all. I'm not going to touch them. I'll wait to see if they do bend.
  • Slymax
Posted May 01, 2003 - 06:27 AM
What exactly does it do? It would seem to lower the COG but what are the benefits? Is it just for guys with big feet and long legs or are there other benefits?
  • cowboyona426
Posted May 01, 2003 - 06:29 AM
When you do this mod, where does the kick start contact the peg after the mod? I'd be worried about knocking a huge gouge in my kick start after this mod. :)
