xr 600 questions
4 replies to this topic
  • vincent1
Posted July 16, 2004 - 10:25 AM
Hi guys,
just bought an 85 model xr with a 92 eninge. The dealer who sold it to me didn't know anything about this bike, so here are some questions, you might be able to help me out:
-what type of oil goes into this engine: 10w40, 15w40 or else?
-what type of spark plug does it need?
-how much oil do i need to flush the old crap, install a new filter and fill her up again?
-How do you check the oil with the dipstick? (when hot, cold, directly after shutting down the enginge, or else?
-Is it normal that the whole engine becomes pretty hot; so hot that you cannot rest your hand on the clutch-cover without burning your hands? (still plenty of oil in it, good condition engine, drive with a temp. of approx. 20 degrees outside)
ok, thanks in advance, have fun, vincent
  • XrCanuck
Posted July 16, 2004 - 01:59 PM
To check the oil start it let it idle for 2-3 minutes. Shut off engine let oil settle. Remove dipstick clean it and then put the dipstick onto top of the threads in the hole but don't screw it in. This is how you are supposed to check the level at least this is what the shop manual says.
The oil type depends on your riding temperature. 10W40 will give you a pretty good temperature range.
oil capacity is 2.1 quarts or 2.0 litres from oil drain
or
2.6 quarts or 2.5 litres from rebuild.
I didn't know that a newer engine would fit in an old frame. Does the bike have 1 or 2 carbs out of curiosity.
  • XrCanuck
Posted July 16, 2004 - 02:07 PM
The spark plug for 1983 on is
ND X24EPR-U9
NGK DPR8EA-9
gap 0.8-0.9mm or 0.032-0.036in
  • JetPilot
Posted July 16, 2004 - 06:54 PM
If you love your engine, and want it to last a long time, use synthetic oil !!!! :thumbsup: Mobil 1 red cap synthetic is a good oil and you can find it everywhere. :devil:
  • vincent1
Posted July 16, 2004 - 08:58 PM
[/QUOTE]
Yes, it does fit, i didn't do the conversion, so i can't tell all details, but it looks like it's allways been there, no dumb pieces of self made iron to suspend it or something. Its got a single keihin carb. Cheers! :thumbsup:
  • Hot  29 replies
  • 17 replies
  • Hot  60 replies
  • Hot  186 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
