Easy and Helpful clutch rebuild!!!
8 replies to this topic
  • DoctorRzed
Posted August 11, 2002 - 01:28 PM
You aren’t quite sure. Was it bad traction or was it the clutch? If you’re wondering about the clutch, it almost always is the clutch . And once a clutch starts slipping, its wear rapidly accelerates. If you catch it early, though, you can save your day with a dirty temporary fix.
Step one: Push on your rear brake caliper. This is a shortcut you’ll thank me for later.
Step two: With the brake caliper piston depressed, you’ll be able to remove the clutch cover without removing the rear brake pedal. Just depress it until it hits the footpeg.
Step three: Take note of which plates go in first and last. Some bikes have a different plate on the very bottom of the stack. Virtually all clutch stacks start and end with fiber plates, so there will be one more of these than there will be driven (metal) plates.
Step four: Now that you have them out, forget everything you know about clean work habits. Drop the plates in the dirt and rough them up. Don’t stop until they are good and scratched. Then clean them off with contact cleaner.
Step five: Now find some old spark plugs and steal the washers. Usually, they are the right diameter to add preload to the clutch springs. Put them in before the springs when you reassemble the clutch.
Step six: Change the oil. Use a conventional motor oil instead of some fancy synthetic. In this case, slippery oil isn’t a good thing. When you put everything back together you might have about one moto of slip-free riding if you don’t abuse the clutch. This isn’t a permanent cure, just a delay until you can get new plates.
  • Endosports
Posted August 14, 2002 - 09:50 PM
What? Who are you? and what are you doing here?
  • therapture
Posted August 15, 2002 - 04:32 AM
This is the local idiot trying to make up for his other mundane and stupid posts. Just ignore him, and maybe the llama will go away! He probably did not even write that tip, I bet he cut and pasted it from somewhere else.
  • DoctorRzed
Posted August 15, 2002 - 04:46 AM
Yes it is not my work but I read it somewhere and thought it was a good tip. I tried it and it workk fine for me.
  • John_Lorenz
Posted August 15, 2002 - 05:26 AM
The only thing this kid has posted that has any valueis this
From Pumel Whats his name
And Ya got it all wrong to boot
Look take the plates (Fiber) and place them on a flat surface (Mirror or Whatever) using 1000 grit wet paper. place the fiber plate down and do a figure eight on the sand paper. A few rounds each side will break up the galze that is created on the fiber.
Do the Same thng with the alluminum plates.
This simply is a new clutch or maint thing ya do prior to putting new clutchs in or placing your old clutch back together.
Never drop it in the dirt son....Geez and never forget good clean work habits
[ August 15, 2002: Message edited by: E.G.O.**** ]
  • RedRider110
Posted August 15, 2002 - 06:41 AM
Did you change your clutch before or after you got 6th in the national points? :)
  • DoctorRzed
Posted August 15, 2002 - 08:25 AM
Ego I didnt write this I got it from an older magazine, but when I did it I used a light sanding sponge.
[ August 15, 2002: Message edited by: pavelkod ]
  • beezer
Posted August 15, 2002 - 08:33 AM
Pavelkod,
You have been outed.
Once people find out you are a BSer they don't want to listen.
I would wait a while and come back on with a different handle.
Until then your going to get nothing but abuse.
  • holeshot
Posted August 15, 2002 - 09:16 PM
Yeah, I read that "tip" in MXA a while back. :) I think you'd have to put heavy emphasis on the word "emergency".
How about another MXA "tip" - leave your gear on until after you load up your bike. That way you won't get your regular clothes dirty. Are these guys sharp or what? :D
[ August 15, 2002: Message edited by: holeshot ]
  • On January 15, 2017
  • 10 replies
  • Hot  30 replies
  • Hot  47 replies
