What size brass oil bolt wahers on 2000 426?
4 replies to this topic
  • Guest_BrandonV_*
Posted July 15, 2004 - 01:23 PM
Mine are toast and I want to have replacements ready next time I change the oil. Anyone know what size to get?
Thx.
  • John_Lorenz
Posted July 15, 2004 - 01:33 PM
I believe they are 12mm as the bolt it self is 12mm. :thumbsup:
  • Guest_BrandonV_*
Posted July 15, 2004 - 01:34 PM
how about the frame mounted bolt? any idea?
Thx.
  • John_Lorenz
Posted July 15, 2004 - 01:35 PM
the frame drain I assume that is 10mm
The screen filter at the base of the frame is 17mm I believe maybe 14...
  • jmw00
Posted July 15, 2004 - 01:55 PM
Maybe this will help I just went and purchased 10 each of all the crush washers on the bike here are there part numbers. i don't see a size but this is there oem numbers... Main oil plug for case washer # 90430-12213, Frame washer # 90201-08087, crush washer for radiator drain # 90430-06014-- if you call your local dealer and give them these part numbers they may be able to tell you the exact size of the washer :thumbsup:
  • Hot  50 replies
Motocross
  • Hot  491 replies
  • Hot  36 replies
