expert advice!!!!!!!!
6 replies to this topic
  • ltrosson
Posted August 09, 2002 - 02:38 AM
Have been a faithful user of yamalube 10-50, the problem is I can drive two hours to get and nobody seems to be able to get it right now. I am from the school of what you start with you stick with, but I want to know can I safely change to another oil that is easier to get. What brand and weight??????
  • crazyadam
Posted August 09, 2002 - 04:54 AM
I just switched from Yamaha 4R oil, to Mobil 1 15-50 ...NoN- energy conserving oil. (in the circle on the back of the bottle) cheaper and easier to find.
  • yznvegas
Posted August 09, 2002 - 05:19 AM
I use Motul 20-50, it's cheap at cycle gear.
  • Hokie
Posted August 09, 2002 - 05:33 AM
Ditto, all my thumpers have run on this stuff, no problem. Look for the red cap.
  • sirthumpalot
Posted August 09, 2002 - 06:22 AM
You're probably going to get replies representing almost every major oil brand available. If you go with a name brand that matches the spec in the manual then I'm sure you'll be OK (it specifies motorcycle oil marked SJ right?). Other oils will work I'm sure, I'm just a stickler for following the manual. :)
  • ltrosson
Posted August 09, 2002 - 08:39 AM
I appreciate the replies, is it no big deal to switch from 10-50 to a 15-50 weight?
  • John_Lorenz
Posted August 09, 2002 - 09:01 PM
From SirThumpy
In the Betty Crocker book it says to use a butter flavored Oil :) Ahh Never Mind, Sure wish you could make it to the TT run
  • Hot  50 replies
  • 10 replies
  • 9 replies
