Cam Timing help
did it stop while the bike was running? If so it's almost certain that valves are bent. No offence intended, but from the posts you have submitted it may be a good idea to get some professional help, or at least a friend who knows his stuff. Cam timing must be perfect, no room for error at all.
It can be done by yourself if you have the manual, and a friend that has experiance with engines. The manual is the most important thing. I'm 15 and with the help of my dad, who put the valves in only, we got the same thing you are doing done. Bent intake valves, jumped cam chain. New intakes, and a new cam chain. But if it happned at a good RPM for you, you could have a broken valve, damaged head, cracked piston, among other problems. ?
